424,454,464,2400,2500 hydraulic question
kirk
11-20-2003 16:17:08
Help! The hydraulics on my 2400a make a loud high-pitched squeeling noise that seems to change pitch when the steering wheel is turned. After about 30min of running the hydraulics over-heat and the unloader valve sticks leaving the 3 point lift stuck in the up position. Everything works fine until it gets too hot. The Wet brakes had wore out and put a lot of grindings in the oil. I've replaced the brakes, oil, and filter a few times until it looked clean. Any body had a problem like this? Thanks in advance.
the tractor vet
11-20-2003 20:04:15
 Re: 424,454,464,2400,2500 hydraulic question in reply to kirk, 11-20-2003 16:17:08
Sounds like you have a regulator valve sticking , some how some of the brake particals got past the filter and got stuck in the valve or you are sucking air somewhere. Had a bearing go bad on the axel of a 460 that i had and it got thru the whole system and would cause the presure Reg to stick closed and would just kill the tractor dead in the most inconveint times LIKE AT A TRACTOR PULL or on the road ,,Went thru several CASES of filters and around two hundred gal. of hy tran tryen to clean it up.
kirk
11-21-2003 19:26:55
 Re: Re: 424,454,464,2400,2500 hydraulic question in reply to the tractor vet, 11-20-2003 20:04:15
Thanks Tractor Vet!
