farmall 400 lp
FARMIN RED
11-21-2003 06:04:28
Where do you find the serial plate on a 400 lp. and what are they worth. fair rubber, working TA, runs, original shape
Thanks for your responses
Bob K
11-21-2003 07:11:05
 Re: farmall 400 lp in reply to FARMIN RED, 11-21-2003 06:04:28
S/N plate should be on the bell (clutch) housing (right side I think). Worth $1800 - $2200 depending on where you are and if it's in good condition. A decent running 400 with working TA and pretty straight sheet metal is worth at least $2200 if everything works on it (hydraulics, PTO).
GT
11-21-2003 08:23:24
 Re: Re: farmall 400 lp in reply to Bob K, 11-21-2003 07:11:05
I gave 2500.00 for mine with a thrasher. This was in TX. It may have ben a little high but it was close, in good shape, and needed a little TLC, (valves, tuneup, battery). I was able to drive it home.
Good luck with your LP. One of the other selling points was how clean the oil on the dip stick was.
On a '56 even.
