1948 C international
tom levad
11-21-2003 07:40:35
I have an early 1948 C International Tractor. Serial no. 1815. Does anyone have the manufacturers seal number for the brake drum shaft seal. I would like to order new ones before I tear the old ones out.
Stan(VA).
11-22-2003 04:27:56
 Re: 1948 C international in reply to tom levad, 11-21-2003 07:40:35
It's entirely possible that you have sn 1815, but note that all the C and Super C tractors have the #1815 on the serial number tag listed as engine no-load max rpm. Don't recall at the moment but I think it's at the lower right side of the tag, or maybe just on the bottom line.
Stan(VA).
Randy in NE
11-22-2003 12:01:19
 Re: Re: 1948 C international in reply to Stan(VA)., 11-22-2003 04:27:56
Good point Stan. A year ago when I bought my second C it was advertised as a '48. The only number they could make out was the 1815 on the tag on the seat support. This turns out to be stamped in the tag. After I bought it I checked the serial number of the engine which is located on the side of the block just below #1 spark plug on a flat machined spot. Turns out it was actually a '50 and only two mumbers off from the first one I puchased. Now to find the one that is in-between.
John in Ne.
11-21-2003 20:08:00
The serial# on my "C" is 1727,maybe built the same week or even the same day!Anyway,I believe the numbers you need CHR11171 andCHR23710. These are for the brake seals and the brake pedal shaft.While I had mine apart I replaced both.These are the Chicago Rawhide numbers and any parts house or bearing jobber should be able to get them alot cheaper than IHC.
John in Ne.
11-21-2003 20:10:42
 Re: Re: 1948 C international in reply to John in Ne., 11-21-2003 20:08:00
I didn't replace my dust seal,didn't need to.
CNKS
11-21-2003 18:31:54
Oil seal is 351 108 R91, dust seal is 63 090 D. You will find a parts manual indispensable, and you won't have to worry that I gave you the right numbers.
