Brass Lift-all cylinder value?
Zak
11-21-2003 21:02:55
Found a brass exhaust lift "lift all" cylinder today for the A's and other smaller IH tractors. Are these things worth anything? I could pick it up for next to nothing a rebuild it to sell, but I personally don't have any use for it. It's currently mounted on a junked A. Anyone know what they might go for in decent shape?
Sid
11-23-2003 01:20:59
 Re: Brass Lift-all cylinder value? in reply to Zak, 11-21-2003 21:02:55
Zak, Is the gas diverter valve, or pressure valve as it was sometimes called, still attached to the exhaust manifold. I need one to complete my Lift-all setup and would be interested in it. Thanks, Sid.
Red Dave
11-22-2003 06:29:40
By all means pick it up. I don't know what it's dollar value is, but there aren't many brass ones around.
gene b
11-22-2003 02:53:05
Does it have any dents? I would like it but all i need is the brass piece. Take the four bolts apsart and top and bottom will come off. e-mail price for what you would want. The early ones were BRASS.
Zak
11-22-2003 10:12:19
 Re: Re: Brass Lift-all cylinder value? in reply to gene b, 11-22-2003 02:53:05
No dents that I could see BUT there is some mild pitting up and down the backside for about 1/4 of the cylinder. Top to bottom, 1/4 of the way around. It didn't look too bad to me and the top and bottom pieces looked like they could be cleaned up easily. It is brass with a dark patina but it could polish to a bright shine with a little 'Brasso' and elbow grease! What are these things worth?
