m steering bolster
allen
11-21-2003 22:08:53
does anybody have the part numbers for the oil seals for the steering shaft and bolster pivot shaft?
TDK
11-21-2003 23:41:41
 Re: m steering bolster in reply to allen, 11-21-2003 22:08:53
IH# 43800DA or C/R# 9876-Str. Shaft Seal
IH# 359789R91 or C/R# 15039-Upper Bolster Shaft Seal.C/R seals can be found at local auto parts store or nearest bearing & seal supplier.These will probably save you some money as compared to IH parts.
allen
11-22-2003 06:34:37
 Re: Re: m steering bolster in reply to TDK, 11-21-2003 23:41:41
thanks TDK Would you have the seal no. for the PTO shaft?
TDK
11-22-2003 23:25:47
 Re: Re: Re: m steering bolster in reply to allen, 11-22-2003 06:34:37
P.T.O. seals:IH#358812R91----C/R#13676 IH#358772R91----C/R#15330
Either seal will work.Good luck with the "M".
