That is good information very much appreciated. I went to my farm a few minutes ago and looked at the marks on the ring inside the pump where the inspection plate was removed. The inspection plate is held tightly by two small cap screws against a gasket to stop any leakage of fuel. I turned the pump slowly by rotating the harmonic balancer with my left hand and holding a light with my right. Very strange to me is the ring with timing marks has 8 such marks equally spaced and in alphabetical order. The first mark has A -, the second mark B -, and so on until H - comes into view. After H - a small "1/2 moon" is part of the ring with the letters as described. I cannot find any stationary item within the pump to align the marks! And if I do find it, I don't know which of the letters represent TDC! Therefore, if you will be so kind as to research this on my behalf I am most grateful. I have a Jensen Manual for IH 3444 but it makes absolutely no reference to the fuel system. Mostly front end loader and backhoe references instead. Again, THANKS FOR YOUR REPLY AND HOPE TO HEAR MORE FROM YOU. MY EMAIL IF YOU WISH TO EMAIL ME IS wchavis@aol.com
