Farmall ignition switch
Clete
11-22-2003 11:31:41
The ignition is the simple pull out/push in. In completely rewiring does it matter which screw terminal is run/stop as long as it is wired right?
J in Pa
11-22-2003 16:22:58
 Re: Farmall ignition switch in reply to Clete, 11-22-2003 11:31:41
clete. is it a magneto or distributer?.
a mag uses one lead and a distributer uses two. and there are two different kind of switches.
J in Pa
The Red
11-22-2003 11:33:30
Clete use either terminal from the hot side and the other terminal to the coil. Desn't matter.
Bob in SE Nebraska
11-22-2003 13:49:31
 Re: Re: Farmall ignition switch in reply to The Red, 11-22-2003 11:33:30
Good to "see" you around Red.
Bob
The Red
11-23-2003 14:29:59
 Re: Re: Re: Farmall ignition switch in reply to Bob in SE Nebraska, 11-22-2003 13:49:31
Thanks Bob Had my hands full with ill elderly parents since Labor Day weekend. They are back in fairly good health.
