HELP! 49 Farmall not running right.
Josh Hoffman
11-22-2003 13:02:05
I have ben having trouble w/ my 49' "C"...I have replaced the spark plugs/ wires/ points/ battery/ new starter, intake manifold gasket & carb mounting gasket & rebuilt the carb....now, I can get it running but it backfires & "spits", & "pops" & it fouls the plugs ...does this sound like a intake valve problem?
Randy in MO
11-22-2003 19:05:42
 Re: HELP! 49 Farmall not running right. in reply to Josh Hoffman, 11-22-2003 13:02:05
Did you replace the condensor? I have had new ones that were'nt "right" make a tractor run just like what you've described. If so, try putting in the old condensor and see if it runs right.
Hugh MacKay
11-22-2003 16:10:32
Josh: Just a hunch, did you by chance go wrong way around your distributor with wires for firing order. I did this in a hurry one day, and what you describe sounds very familiar.
tall corn
11-22-2003 15:39:09
Sounds like the timing could be off. Did you set the timing after you changed the points. You will need to.
Hugh MacKay
11-22-2003 21:57:40
 Re: Re: HELP! 49 Farmall not running right. in reply to tall corn, 11-22-2003 15:39:09
It is probably 45-50 years since I changed my first set of points on a Farmall. Most of the time since I have had 2 to 4 of those 4 cylinder gassers. I'm thinking I probably changed 75-100 sets of points in my lifetime. I could count on one hand the number of times I adjusted timing as a result of the new points. Of those 5 times timing was probably off before points were changed. I fail to see how changing points in a Farmall could affect the timing.
Oh and by the way about 3 weeks ago I went to shed, my 3 tractors hadn't been going in 2-3 months. They each fired up within 20 seconds. I cant remember the last time timing was set on my Super A or 130. I know 140 was timed last spring, as I had just bought it. I don't recall that it was anymore than a check, as I didn't change it. I did throw away the cruddy set of points and condencer that someone bought at a nickel and dime store.
My 140 is a bit of and amusing story as it had been owned by 3 guys that hadn't been able to get it going in the past 5-10 years. I've heard various stories on that one. A neighbor and I went to pick it up and we had it running well enough to load on his truck within 5 minutes. We took with us fresh gas, good 12 volt battery and most ign. replacement parts. The gas and battery were all that was needed that day.
farmall-dave
11-22-2003 16:48:37
I agree with tall corn, also check your valve clearances.
Cheers
