Super C weight
Chuck A
11-23-2003 22:10:28
Can anyone tell me how much my 51 super c weights and the size of trailer I need to haul it. Chuck A.
Hugh MacKay
11-25-2003 02:59:40
 Re: Super C weight in reply to Chuck A, 11-23-2003 22:10:28
Chuck: I would go with what CNKS said, I have a trailer that size to haul my tractors. My brother has used it many times to haul his 230 and pulling it with his S-10 Chevy 4x4. Sometimes I wonder if he doesn't get along better than I do with my 3/4 ton 2wheel drive diesel. He uses torsion bars, I don't, but I can also put tractor between trailer axles and hitch.
CNKS
11-24-2003 09:49:19
Actually for a C/Super C a trailer with 2 3500 lb axles is adequate. Assuming the tractor weighs 3500 lbs (this is high, but I am allowing for wheel weights, etc, and the trailer 1500, thats 5000 lbs including trailer that has capacity of 7000 lbs. Advantage is that it can be towed with a half ton pickup, without exceeding the gross combined vehicle weight. If you have a bigger pickup, whatever works for you.
Farmer Bob
11-23-2003 22:55:50
Chuck,
I'd say around 3,000 lbs without rear weights or fluid in the tires. A standard double axle 18' equipment trailer rated at 8-10K should be just fine.
