Need help with I-544 3 point adjustment
Gramps544
11-24-2003 11:55:26
third party image
I have a I-544. My lift control level is very loose. It wants to return to the forward position (toward the front of the tractor). This is very difficult to use as I have to leave my hand on the level to hold my 3 point lift at a given height. In my manual it states to move these two nuts with a punch. I tried using my punch, a large nail, even an old allen wrench (stuck it in the hole and hit it with a hammer) and the nuts will not budge.
This is a very small space to work in. Can anyone give me some hints on how to move these nuts? Picture show nuts right under the hydro. accessory valves.
Bruce Wa.
11-26-2003 15:33:27
 Re: Need help with I-544 3 point adjustment in reply to Gramps544, 11-24-2003 11:55:26
I have the same thing on my 544. Ffixed really easily by putting a piece of 5/8 heater hose over the handle and fitting it down in the slot that the handle comes up through. works well for a couple of years then put on anew piece of hose . it only has to be about 4" long
Gramps544
11-25-2003 17:12:12
I do not know why the picture does not display correctly. Anyways, anyone ever adjust these 3 point level nuts?
