Re: Alternator on a 300 Utility
Bob M
11-24-2003 16:30:55
My advice: Take that old regulator off and throw it away! It's only gonna cause you confusion sometime later on...
Anyway the hot wire from the ammeter BAT terminal should go to directly to the ammeter + post. All the tractor accessory load wires (ignition switch feed, light switch feed, etc) should go to the ammeter + post too. The other ammeter post should connect direct to the battery + terminal (this can be via the starter switch "hot" terminal).
Punch below for a diagram that may help...
Mike J.
11-25-2003 11:17:38
 Re: Re: Alternator on a 300 Utility in reply to Bob M, 11-24-2003 16:30:55
Thanks for the advice. I appreciate the wiring diagram.
