Lost my Hydraulics
Higgi
11-24-2003 19:58:53
I just purchased a 340 w/2 point .After tuning it up I checked the Hyd. fluid it had some water in it and it was dirty. So I changed the fluid and filter. Now I have no hydraulics, I tried putting some fluid in though the check ball at the pump to make sure I didn't lose the prime, no luck !
The hyd. worked fine just whiny like it was low on fluid which is why I checked it. Any suggestions would be great !
twopop
11-24-2003 20:06:42
 Re: Lost my Hydraulics in reply to Higgi, 11-24-2003 19:58:53
loosen the output line at the pump and start up the tractor.it should prime itself.my 350 does the same as yours.
