Belt pulley on ebay
GT
11-25-2003 13:59:27
OK Guys, How about that wooden one for $3.00. Anyone ever used or even seen a wooden one. It's laminate but I'd be afraid of flying splinters.
Haas
11-25-2003 18:54:52
 Re: Belt pulley on ebay in reply to GT, 11-25-2003 13:59:27
Well, I've wondered about redoing one that way. I think it would be OK. I grew up with these things in the 50s. We needed a larger belt pulley to use on the MD to run the hammermill because the one we had did not run the hammer mill fast enough. My Uncle made one totally out of wood. It was solid laminated wood with the bolts through the wood to the pulley flange, I suppose turned on some sort of makeshift lathe. Never caused any problem and was used for years. These pulleys only turn at around 900 rpm, and I think the wood would work just as good as the paper laminate.
Nebraska Cowman
11-25-2003 16:32:41
never saw a wooden one. are you sure? I could not find it doing a search in farm for both wood and wooden.
Larry in CO
11-25-2003 18:44:28
 Re: Re: Belt pulley on ebay in reply to Nebraska Cowman, 11-25-2003 16:32:41
Look on EBAY under FARMALL BELT PULLEY or punch below to see it. Larry
Nebraska Cowman
11-26-2003 03:59:18
 Re: Re: Re: Belt pulley on ebay in reply to Larry in CO, 11-25-2003 18:44:28
hummm, I can't see a thing wrong with it. Many of the old thresher pulleys were made of wood. Looks like it needs bought.
Larry in CO
11-25-2003 16:12:14
Saw that one. Thanks, but I'll stick with the fiber ones. Larry
Dick Davis
11-26-2003 02:24:01
 Re: Re: Belt pulley on ebay in reply to Larry in CO, 11-25-2003 16:12:14
After looking at the pictures I'm not sure it is wood. Suppose the seller is just assuming the material is wood becasue paper wouldn't make sense to a novice? My nickel.
