F-12 High Compression Piston Question??
Mike Androvich
11-25-2003 14:35:54
I am rebuilding a F-12 engine and since the original pistons were bad, I decided to install a set of high compression pistons I had laying on the shelf. My question is which way to put them on the rod? The tops of these pistons have a sloped side and a notched side. Which side towards the spark plug? The sloped side makes the piston stick above the top of the block and the notched side puts the top of the piston flush with the top of the block. I would assume the notched side would be towards the plug, which gives a larger ignition volume, but I am not sure. Anybody out there know which way? Thanks a bunch!
Farmall Daddy
11-26-2003 13:39:57
 Re: F-12 High Compression Piston Question?? in reply to Mike Androvich, 11-25-2003 14:35:54
My Dad did this once to an F-14. One thing to do before you try tightening anything down, is put one piston in the motor, connected like a normal piston, put the head on, and turn the motor over by hand. If it picks the head up, then the piston is backwards. Do the same thing so you don't bend your valves if it doesn't work either ways. Best of luck with it!!
Karl Olmstead
11-26-2003 12:16:17
What you're describing doesn't make sense to me, Mike. The piston's the same height regardless of which way it is installed; the only thing that should change is whether the part of the piston that sticks up is on the valve side of the cylinder head or the other side. In the F-14, the part of the piston that sticks up above the block fits into the recessed portion of the head that has the valves. I haven't seen one, but from what Justins tells me, the F-14 head is like that of the A/B/C engine.. the valves are recessed and the other half of the combustion chamber is flush with the block. The F-12 has that huge domed combustion chamber, so it wouldn't matter which side the piston 'bump' went on. Pistons usually have an arrow on the side intended to be forward.
ET
11-26-2003 08:07:39
Look at the chamber in the head if you put them in backwards they will hit the head.
justin
11-25-2003 16:09:36
The pistons you are describing are actually F14 pistons.. F12 high altitude pistons are just a full piston with a longer compression distance.
Mike Androvich
11-26-2003 19:24:19
 Re: Re: F-12 High Compression Piston Question?? in reply to justin, 11-25-2003 16:09:36
Thanks for the ideas. I have come to the conclusion that I am putting F-14 pistons into a F-12 block. I had forgotten that when I rebuilt a F-14 about 20 years ago the head indeed has a portion that was flat to the block, making the pistons only able to go one way. Since I am putting F-14 pistons into an F-12 head, there should be clearance with the piston in either orientation. I am going to install them with the notch towards the spark plug and see what happens. Thanks again guys for all the help and ideas!
