Help! Possible damage??? 6V system
Josh
11-26-2003 14:13:49
Quick question about 6V positve ground systems...I have a 49' "C", just got a new head put back on the tractor & I had a "brain fart" & put the 6V battery back in w/ positve to starter & negative to chasis ground...the tractor started right up, but, now I'm wondering if I did any damage? The starter turned very slow, but it came right to life...my gages quit working, so I don't know if I was disscharging the battery or not...I am more consirned w/ any damage I might have done to the electrical components...the tractor was running for 1hr or so.
Steve - IN
11-27-2003 06:26:17
 Re: Help! Possible damage??? 6V system in reply to Josh, 11-26-2003 14:13:49
Josh,
The voltage regulator is the one thing that may have gotten upset about your brain fart. If you wire it back + ground and the ammeter shows charge, no damage done. If you get not charge, or discharge - try repolarizing. You can find that procedure described 50 times by searching the archieves here. Worst case is you might be in for a new voltage regulator.
Allan
11-26-2003 14:41:29
Josh,
No, you didn't hurt anything; you will probably have to re-initialize that generator tho after you turn things around.
Allan
Michael Soldan
11-26-2003 14:32:19
Josh you probably didn't hurt anything, set it up right and try the tractor..your gauges would be weird but when all is said and done it will likely be ok...Mike in Exeter Ontario
