looking for year on Farmall A w/o a serial tag
Jonathan
11-26-2003 14:26:57
Hello, I came across a farmall A and I wanted to look up the year, but I guess the tag had been removed because I couldn't find it anywhere, so I took down some casting numbers hopeing someone out there has a book on them. On the left side of the transmission 8638-DD, on the right side of the block 6342-DH, on the top right hand side of the block just before the head FAA97570.
I was thinking of buying this tractor, but with the missing tag, it has me leary, but I'm still curious as to the year of manufacture.
thanks in advance!,
Jonathan
gene b
11-26-2003 16:44:08
 Re: looking for year on Farmall A w/o a serial tag in reply to Jonathan, 11-26-2003 14:26:57
FAA 97570 serial# on block means early 1944 serial number should have been the same on the seat unless someone has replaced the motor. Casting code would have an M or N after the day and month it was cast. Those other numbers are the part number of the casting look on the transmission rite beside the clutch pedal and there should be the cast code like 01*15*N .
Nebraska Cowman
11-26-2003 16:11:16
look for date codes on the castings. (month-date- letter code for year)
