460 UTILITY SPOOL VALVE SET UP
CHRIS
11-26-2003 16:54:34
IM LOOKING FOR THE SPOOL VALVE SET UP FOR A 460 UTILITY. I THINK I FOUND ONE FROM A 560 ROW CROP. WILL THIS FIT OR SHOULD I THINK ABOUT SOMTHING ELSE?
Jeff
11-26-2003 22:45:48
 Re: 460 UTILITY SPOOL VALVE SET UP in reply to CHRIS, 11-26-2003 16:54:34
Chris, 460 Utility was the same tractor as a 340 utility other than the six cylinder engine and the length of the hood. The 340, 460 and 560 all used the same valves but, the row crops (Farmall) had different outlet manifolds/blocks than the utility(International) version.
Your 560 spool valve will work but you will need a 340-460 utility (International version) manifold or block assembly to get fluid to the ports. Not enough clearence under the utility dash for (Farmall version) plumbing to the ports.
