Order Farmall Cub Parts Online
slow / no return on 48 Cub clutch pedal
Dave
11-27-2003 09:11:34
I recently got a 48 Cub in decent working order to restore. My wife has been using it around the farm to haul my small speader. The clutch pedal has lost its ability to return to the starting position(and engage the trans) without some upward pressure on the back of the pedal. It was not like this when I first got it. I have lubed the return bearing, checked the fluids and made sure there is nothing external impeding the movement. It disengages the trans, and if you sit and wait long enough, the pedal will eventually rise enought to engage the transmission if it is in gear and running.
49 Cubber!
11-27-2003 16:18:54
 Re: slow / no return on 48 Cub clutch pedal in reply to Dave, 11-27-2003 09:11:34
This probably isnt your problem,but did you check to see if the spring is still there up under the floor pan?If so Id suspect the pressure plate.
peterc
11-27-2003 11:39:37
your clutch pedal is probably binding at the bushing lube it and use a little heat it should loosen up
