TD9 Safety Advice
Marc
11-27-2003 11:21:38
I have a TD-9 that I'll be using in a relatively hilly area. It has No Roll-cage or Seat-belt. I am seeking advice on:
1. How important is a Roll-cage/seat-belt on this machine? I heard one word of advice that if I don't have a roll-cage, don't use seat-belts ... so I could 'jump' out if I need to.
also,
2. Roll-cages. I have access to square steel 4"x4" (I think?) tubing and a welder. Just wondering about the best attach-points and cage design.
I can post pictures if it'll help.
Thanks!!
-Marc.
old
11-27-2003 15:47:13
 Re: TD9 Safety Advice in reply to Marc, 11-27-2003 11:21:38
If you build a roll cage ithas to be strong enough to hole around 20,000 lbs which is hard to do, On hills run up and down them not side ways, if you try to run side ways you can slide and very likely roll it. Get an origanal owners manual for it, as it tells you the safety tips of that machine
farmall-dave
11-27-2003 16:17:35
 Re: Re: TD9 Safety Advice in reply to old, 11-27-2003 15:47:13
If your on hill work and you have to turn anyway, turn up hill,they will climb almost vertical, but you have to be experienced if you want to go down hill;for one thing as soon as you pull the a clutch lever,r/h side say, the machine will immediately will turn left, UNLESS you put your foot on the BRAKE at the same time.They can be a trap for young players.
Rudi
11-27-2003 16:47:42
 Re: Re: Re: TD9 Safety Advice in reply to farmall-dave, 11-27-2003 16:17:35
third party image
I have just spent the last year learning how to use a TD7-TD8 IH/Dresser dozer. So I can still remember how terrified you can get when you start working on a hill. Even after a year of grading around my pond, brook, ditches and hillsides, it still puts the fear of God into me. Working on hillsides is NOT for beginners. Get real comfortable with using that dozer. They have a tendancy of biting when you least expect it. It takes an awful lot to roll a dozer, but I seriously doubt if it would be survivable without a properly engineered ROPS. A home made roll cage would not be adviseable.
IH spent serious time and dollars developing their roll over cages for the TD 7 - 9 series dozers, as they are used extensively for landscaping. They are highly mobile and can climb almost impossible angles on hills and I have seen them work on very steep hillsides. But the key here is that those who are operating in that type of scenario are highly skilled operators, most with decades of experience. I would not even attempt it without a qualified dozer operator to supervise and properly instruct.
This is just my own personal opinion gained from a somewhat limited amount of time as a dozer operator. (since last October I think I have about 750 hours on the dozer)
