Order Farmall Cub Parts Online
Re: 48 Cub with a charging problem
gene b
11-28-2003 03:18:04
First when sw is on should show discharge as amps going to coil. When it runs ground the field term of the gen to a good ground if then it shows charge it is the reg.maybe you need to polorize the gen by just momently touching the Batt term on the reg to the terminal on the gen marked with A using piece or wire. Use a meter to make sure the gen is ground to the frame also the reg is grounded also the control where the amp is mounted.
