Farmall H engine ?'s
Farm w/Junk
11-28-2003 09:42:17
Hi I have a 1946 farmall H Im going to work on this winter.I just plan on new rings rod bearings, head cleaned and whatever they do to it, and a carb overhaul. What size pistons does it have? I have a chance to buy a set of new old stock IH pistons 3 9/16ths I think out of a 350. Wouls these fit if I took my sleeves out and put the new ones in? The set includeds pistons, sleeves, pins. What is it worth? He is also going to throw in a set of firecracker domed pistons(one is scored) and some used valves. What is this all worth? How much do the pistons weigh? Thanks
Matt
T im Kincaid
11-28-2003 15:59:17
 Re: Farmall H engine ?'s in reply to Farm w/Junk, 11-28-2003 09:42:17
H's came out originally with 3 and 3/8 bore I don't think those 350 sleeves will fit. It probably already has 3 and 7/16 oversize in it though since it might have been overhauled once already. Have fun this winter working on it. Tim K.
Nebraska Cowman
11-28-2003 17:22:22
 Re: Re: Farmall H engine ?'s in reply to T im Kincaid, 11-28-2003 15:59:17
hey tim haven't heard from you for a while. the single front is still here waiting
Farm w/Junk
11-29-2003 12:47:33
 Re: Re: Re: Farmall H engine ?'s in reply to Nebraska Cowman, 11-28-2003 17:22:22
How much does a single front weight? How much less then dual front? How hard to switch? Thanks
Matt
