differences 400 vs 450
Red
11-28-2003 12:30:44
I'am having trouble telling the difference between a 400 and 450 farmall mid fifties. Any easy way?
dick
11-29-2003 09:16:35
 Re: differences 400 vs 450 in reply to Red, 11-28-2003 12:30:44
You can also look at the casting codes on the major chasis parts which look something like MM*DD*Y (month, day, year, where year is a letter code).
For a 400, you should see a Y code of
Z = 1954,
A = 1955, or
B = 1956.
For a 450,
B = 1956,
C = 1957, or
D = 1958.
riverbend
11-29-2003 10:45:24
 Re: Re: differences 400 vs 450 in reply to dick, 11-29-2003 09:16:35
Does the mm/dd/yy date code extend back to Hs ? If so, what would J mean ?
Thanks
Greg
dick
11-29-2003 13:05:33
 Re: Re: Re: differences 400 vs 450 in reply to riverbend, 11-29-2003 10:45:24
J is 1940 according to Guy Fay's book. Have to be a bit careful with this since IH skipped a letter every once in while.
Ron 1456
11-28-2003 19:45:47
On the gasoline tractors the 450 will have a bigger gas tank that sticks down below the hoods a little. The fast hitch on a 450 looks about like the one on a 560. On the 400 it may be different. You can't always go by this because some of the 400's have had these things changed. The only sure way is to check the serial number like FarmallH42 mentioned earlier.
FarmallH42
11-28-2003 18:17:35
400 will have 264 cast into the block
450 has 281 cast into block
450 should have front nose tin white (people paint 400 tin white too)
serial numbers?
Hope this helps a little...
