Will a 460 PTO bolt up to a 400?
Male Gayle
11-28-2003 16:16:53
I recently bought a gas 400 in good shape that is missing the PTO. It was removed to reduce weight for pulling. I have access to a diesel 460. Will the PTO from the 460 bolt up to a 400 without modification? Thanks for any info you can give me.
RPM
11-29-2003 08:27:11
 Re: Will a 460 PTO bolt up to a 400? in reply to Male Gayle, 11-28-2003 16:16:53
I think it will, same unit from all since SMTA, also 300/350/460 had a extra adapter casting you dont use, look in 460 parts catalog, dont try to use last clutch type from 460/560, different setup and drive gearing up front for live drive. Easy spotting is handle, all except last ones had a small knob on forward side of handle, later that would only fit 460/560 has a square handle and square button in center.
Male Gayle
11-29-2003 20:25:03
 Re: Re: Will a 460 PTO bolt up to a 400? in reply to RPM, 11-29-2003 08:27:11
Many thanks, RPM. I will check the 460 parts catalog and also check out the salvage 460.
