Super C snow plow
Kevin Westling
11-28-2003 18:50:36
I need help. I can't find anyone selling a front plow/blade for my Super C so I'd like to convert a Cub plow to fit my Super C. Does anyone have some good pics of how a front plow is attached to a Super C? Or can anyone help me in any other way? Thanks in advance.
ny bill o
11-29-2003 17:44:04
 Re: Super C snow plow in reply to Kevin Westling, 11-28-2003 18:50:36
i bought a super c with a snow plow on it. i don't have a picture, but it has side frames that hook to the back axle, so the push comes from there. there are large (7"?) pulleys bolted on the front of the super c where frame weights would go, and a cable on each side of tractor from the touch control arms to the front corners of the blade. the clinker is that apparently the stock touch control arms didn't have enough throw, so pieces were welded to the t c arms to give a longer throw to lift the blade higher. hope this helps.
Hugh MacKay
11-29-2003 17:30:23
Kevin: There you go, Paul's tractor is the one I was sending you after anyhow. That is the nicest blade setup I've ever seen on a C, SC, 200 or 230. The factory ones like that are very rare, but it will give you something to go by in building.
Paul Shuler
11-29-2003 16:16:56
Here is a few photos of my blade. Don't know if it helps you any or not. I have only scene one other ever for sale and it went on e-bay for big cash.
Hugh MacKay
11-28-2003 22:16:06
Kevin: If you go to photo gallery on this site, type in Farmall Super C there is at least one and possibly two good photos of SC with front snow blades mounted. And good clear photos that will show mounting quite well.
