smta engine overhaul
paul
11-28-2003 19:04:02
its time to overhaul the old super mta how hard is it to get the old sleeves out and are there any special tools nessary.thanks paul
Dan
11-29-2003 09:54:25
 Re: smta engine overhaul in reply to paul, 11-28-2003 19:04:02
Pulled sleeves out of my SMTA several years ago. I cut out a steel circle small enough to go into hole in block but larger than outer sleeve diameter. I drilled a hole in the center and got some ready bolt that would screw into head bold holes, I used a steel piece between those ready bolts and a ready bolt down center with a nut on top and one on bottom of circle. by tightening nut on top you could pull sleeves without damage. Easier to build than to describe
rebuilder
11-29-2003 04:30:44
Paul: I just found out about this trick recently. If you are not planning on saving the old sleeves, take a welder and weld a bead all the way around the sleeve, I assume approx. half-way down. The bead has to be complete(no gaps) to get the contracting power. Sleeves slip right out, no pullers to buy or borrow.
Ron 1456
11-28-2003 19:27:13
We used a sleeve puller that we borrowed from the local dealer. The old sleeves came out without much trouble.
