F20 Manifold
Tony
11-29-2003 09:01:43
Hello all,
I have a manifold off a parts tractor that appears to be in great shape, but looks a little different than the original. Can anyone tell me why and if I should expect any problems?
They can be viewed on my web page.
Thanks,
Tony
Nebraska Cowman
11-29-2003 16:27:30
 Re: F20 Manifold in reply to Tony, 11-29-2003 09:01:43
It is a gas manifold, it will work fine. I have one like it on my Narrow-tread F30 so they can be buddies. I sent you an email about questions you asked about the front removal. Good luck.
ja0091
11-29-2003 09:30:48
your old manifold is a kerosene manifold with a preheating chamber. the other is a gasoline manifold. it will work great. the only problems i encountered are: while running at near freezing temperatures, frost will form where the carb bolts to the manifold. this is from the cooling process when the fuel vaproizes. may cause a little black smoke due to imcomplete combustion.
the other problem will be the location of the exhause pipe. these manifolds have a slightly different location of the outlet, so an alteration to the hood may be in order.
