I need help with Carb for my H!
Zonie
11-29-2003 09:15:57
I was cleaning the Carb for my H today and managed to split the bottom bowl by the main Jet.
I'm wondering if I should just replace this carb or if I should change it out for a 300-350 type carb. I have a manifold for the 300.
I use this Tractor for pulling. I think the 300 carb will help some.
If anyone has a carb that is useable let me know.
Also what do I do with the air cleaner , I think the air outlet on the air cleaner on the 300 is larger in diameter.
tim kincaid
12-01-2003 00:54:15
 Re: I need help with Carb for my H! in reply to Zonie, 11-29-2003 09:15:57
Zonie, I have the carburetor you need. I took it off a c-164 power unit and it is rebuilt on my shelf . email me at tkincaid65@hotmail.com I'm not sure what to ask for it but it is a dandy. See Ya , Tim K.
The Red
11-29-2003 10:33:36
Zonie what is the inlet diameter on that 300 manifold where the carburetor bolts on?
Zonie
11-29-2003 16:44:22
 Re: Re: I need help with Carb for my H! in reply to The Red, 11-29-2003 10:33:36
Red, It's been an awfully long time since I've talked to you! Good to hear from you!
The manifold inlet is the same diameter as an M i belive. I'm not at home wherte I can measure it.
Farmer Bob
11-29-2003 10:27:31
Can't help with the carb but, if the pipe from your air cleaner is smaller than the air inlet on the 300 carb, just add a short length of radiator hose to outside of the air pipe and then a section of the correct size hose over the air inlet of the carb and over the top of the short piece of hose you put on the air pipe. Clamp them down as normal.
