Re: resistor
Dan
11-29-2003 09:46:46
You are referring to the resister in the alternator lead so you can shut it down and keep it from back feeding. I got mine at Radio Shack and we have a pretty small town so would think you could find it there. you can also use either a diode or warning light. When I wired in the one on mine I wrapped tape around it to look good, bad move that sucker gets hot!!
Doug in OR
11-29-2003 10:35:32
 Re: Re: resistor in reply to Dan, 11-29-2003 09:46:46
If this is the resistor for the exciter circuit, you can use a value up to 47 ohms.. maybe even more. This serves mostly as a current limiter. The 2 watt rating is more important - if you leave your ignition on for too long without the engine running, this resistor will get hot. The lamp serves a better purpose here - it exhibits a low resistance until it lights, and then the resistance increases when it glows.
Steve - IN
11-29-2003 16:24:22
 Re: Re: Re: resistor in reply to Doug in OR, 11-29-2003 10:35:32
Ditto on what Doug said if it's for the exciter for an alternator. You'll be way ahead of the game with the light bulb.
