Oil Capacity for M Lift All Pump
Pat Bryant
11-29-2003 17:08:33
What type oil and how much does the lift all pump hold on an M Farmall? Also is there a drain plug to change the oil. Thanks Pat
Nebraska Cowman
11-30-2003 04:02:05
 Re: Oil Capacity for M Lift All Pump in reply to Pat Bryant, 11-29-2003 17:08:33
I didn't reply last night cuz I thought someone would have the specs. Holds something like 2 gallon. I use IH Hy-tran. it is much better oil than the non detergent that was available 60 years ago.
rustyfarmall
11-29-2003 23:25:40
The manual calls for 30 weight non detergent, 20 weight in cold weather, 10 weight in extreme cold weather. But for practical purposes, you can use the same oil that you are using in the engine. Yes, there is a drain plug in the bottom. I don't remember the capacity for sure.
Dan
11-29-2003 21:56:34
Their should be a metal plug on the under side of the resivour. the filler cap should have a dipstick in it.
