a couple questions
Dan
11-29-2003 18:24:11
Working on the SMTA today. Ran compression check, engine had run but not totally warmed up, could still handle spark plugs, throttle open. Showed 120 pounds all cylinders. Squirted a little oil in cylinder and got about 1 pound increase. Does that sound ok? Next question is on steering. I have about 1/8 turn play in steering wheel. Get some wobble when going down the road. The steering gear moves up a bit before turning the shaft to the wheels. I can tighten the top nut and take that out. Is it gonna end up steering too hard if I do that?
CNKS
11-30-2003 09:00:19
 Re: Re: Re: a couple questions in reply to Dan, 11-29-2003 20:17:58
I hope justin forgives me -- the correct address is www.weberstractorworks.com not "parts" --sorry.
