FIRING ORDER ON DIS CAP
JIM
11-29-2003 20:56:15
HEY GUY'S CAN SOME ONE TELL ME THE FIRING ORDER ON DIS CAP FOR A 41 H.I KNOW WHERE #1 IS BUT WHICH DIRECTION ON THE CAP DOES FIRING ORDER GO.THIS MAY BE A DUMB QUIESTION IS #1 PLUG IN FRONT OR BACK OF MOTOR BECAUSE WHEN YOU READ FIRING ORDER OFF MOTOR IT GIVES YOU THE IDEA #1 PLUG WOULD BACK TO FRONT.THANKS TO ALL THAT WILL RESPONSE.I JUST GOT HOOK ON THESE OLD TRACTORS SO I AM SORRY TO SAY THIS MAY NOT BE THE LAST TIME YOU HERE FROM ME. THANK GUY'S
gene b
11-30-2003 02:26:40
 Re: FIRING ORDER ON DIS CAP in reply to JIM, 11-29-2003 20:56:15
You are wright it is confusing the way it is on the block. When #1 is lined up on fire should be in approx 2oclock your cap should be marked #1 there also. Now you did say dis. Mag is the same and rotor goes clockwise on both dist and mag. Take #1 plug out and make sure you are on compression and not exhaust stroke.
Farmer Bob
11-29-2003 21:21:51
Easy fix Jim, looking at the outside plug end of the cap you hook up the wires in a clockwise rotation. The front plug (up by the radiator) is # 1 and then back to #4 at the rear by the gas tank.
If you know where #1 is on the cap, that wire goes to the front plug. Then the next wire from the dist. cap goes to #3 plug, then #4 plug and finally #2 plug. Hope this helps ya out.
