560 overhaul, what to do??
Farmall Daddy
11-30-2003 06:49:22
I just bought a 560 IH gas, that is in need of an overhaul. I dynoed it and it turned 50 horse when it was warmed up. Had massive amount of blowby, but didn't spit and sputter. I pulled it a few times in the 10,000 pound class, and it would probably take it 1st gear, torque ahead. Most of the time I would use the torque. Never ran out of power unless 2ed gear torque back. Should I just put the dome pistons in it? What kind of horsepower would I have. Also, if I bored it out, what kind of horse would I have, along with what kind of different parts would I need. Just finished up the M, and now I have a new project. One more thing, if I bored the motor out, should I put it on the walls, and would that make it overheat if I did so? I found a reasonable place that would bore it, and I figure that I would have the money if you guys think that it would be right. Thanks!!
justin
11-30-2003 11:57:36
 Re: 560 overhaul, what to do?? in reply to Farmall Daddy, 11-30-2003 06:49:22
i do have a NOS set of the IH overbore pistons & sleeves for the 560 gas. These require reboring the block to accept the larger sleeve, and the pistons are stepped head pistons.
Farmall Daddy
11-30-2003 15:17:01
 Re: Re: 560 overhaul, what to do?? in reply to justin, 11-30-2003 11:57:36
Can you oversize the piston any without boring the block. The person that owned my M before me put the oversize kit in in {4 in. medium domes}, but last winter my dad and I bored the motor to a 4 1/8. I didn't know if you could just put the domes in it, or have a thinner sleeve, but a bigger piston. Thanks for any help!!
justin
11-30-2003 20:49:09
 Re: Re: Re: 560 overhaul, what to do?? in reply to Farmall Daddy, 11-30-2003 15:17:01
IH and M&W made the overbore kits, and both required boring the block to accept a larger OD sleeve.
Farmall Daddy
12-01-2003 13:24:02
 Re: Re: Re: Re: 560 overhaul, what to do?? in reply to justin, 11-30-2003 20:49:09
Thanks for the help! It gives me an idea on what to do.
