Positive or neg. ground
John R
11-30-2003 10:09:39
Neighbor just called. needs to know if his H is pos or neg ground. Need ASAP THANKS.
Juan Valdez
11-30-2003 12:12:20
 Re: Positive or neg. ground in reply to John R, 11-30-2003 10:09:39
Always use positive ground in the Southern Hemisphere. It is muy importante!
Allan
11-30-2003 10:20:29
John,
Tell him to look at his battery "positive" cable and see where it is attached.
If it goes directly to the body of the tractor, he is positive ground. If it goes up to the starter switch, it is negative ground.
Allan
Farmer Bob
11-30-2003 10:18:12
If it is still 6V (Three caps on the battery) it is Positive ground. If it's been converted to 12V (six caps or holes on the battery) it should be negative ground.
