M Farmall Hydraulics
Rick Whitley
11-30-2003 17:02:35
I have a 1953 Super M with what seems to be live hyraulics on it. The hoses start at a pump at the distributer and extend back to the belly of the tractor. One of the hoses actually comes into the bottom of the belly. You can activate the belly pump by the lever at the steering wheel. The actual hoses that you would connect to an implement are missing. Can anyone explain this system to me or does anyone have a diagram of how it works?
I also have a 1952 M with just the belly pump. The hoses are also missing on this tractor also. The same information requested above would be helpful on this also.
FM
11-30-2003 19:46:21
 Re: M Farmall Hydraulics in reply to Rick Whitley, 11-30-2003 17:02:35
As far as the live pump goes...
The hose that doesn't go to the belly should go to a valve. This valve will have three hoses coming from it---2 to the rear of the tractor w/ couplers on them, and one to the vent of the belly pump(a hole in the top of the clutch housing).
on the "regular" M, there are elbows with plugs in them on the sides of the clutch housing--2 on the left side, and one on the right. the one on the right and one of the others should lift immediatly when you pull on the rod. The other one on the left is a delayed action cylinder. If you want 2 way hydraulics you'll need a 2 way valve. if single way hydraulics are OK, just run a hose from one of the ports on the side of the housing back to the rear of the tractor and put a coupler on it.
Either way, use a break away style coupler at the rear.
hope this helps
Mike
