super A starting system
mike
11-30-2003 17:30:01
I am about to start sprucing up an old super a it will be used in my rowcrop operation for cultivation and sidedressing. I am unfamiliar with the ins and outs of a positive ground system and frankly do not understand why it is used. The system is currently six volt positive ground, the mag has been bypassed and a coil is used. my questions are:
-why positive ground?
-if I experience any problems with the system as is, is there a tried and true update? (coil vs mag etc.)
-what is and where can i get the last word in manuals for this rig?
-number on head above exhaust reads "251172R1" what year is this machine?
Hugh MacKay
11-30-2003 17:48:19
 Re: super A starting system in reply to mike, 11-30-2003 17:30:01
Mike: If I were going to use that tractor as you are I would abandon that charging system and go alternator. I have done this with three of these little offsets a SuperA, 130 and 140.
You say it looks like someone changed to coil and distributor. Most Super A came with distributor and coil. Your serial number should be under the seat on left seat bracket unless you have a Super A1 and will be on left side of clutch housing. The engine serial which should be close is on a machined surface just under number 1 plug. The number you have given us is a part number only.
On that charging system send me an e mail.
