Parts for 404
Butch Boone
11-30-2003 18:33:37
Could someone tell me the best place with reasonable prices (if there is any) to get parts for my International 404.
Thanks,
Butch
Kip
11-30-2003 18:52:04
 Re: Parts for 404 in reply to Butch Boone, 11-30-2003 18:33:37
Butch,Time patience and good luck I bought a good Farmall 404 almost five years I will finally have it ready to paint in about two month I might be able to help what do you need sheet metal is hard to find thats what I just finished Bates is a good source Wengers has been a good source for 3pt and draw bar parts I am expecting two remote valve levers from them any day I got a instrument panel cluster gauge (the only one that you can get has the feul gauge in it) light switch,starter switch,choke cable,tach cable among other things from Case IH.Tractor supply stocks the dust caps for the remote couplers in red just like the originals I think my tractor will be as close to assembly line new as possible I got other parts in other places just ask I will help all I can I will be posting a before and after picture in the next few months GOOD LUCK Kip
Butch
12-01-2003 16:41:15
 Re: Re: Parts for 404 in reply to Kip, 11-30-2003 18:52:04
Thanks for the info. It will be very helpful in my restoration project.
Butch
Jeff
12-01-2003 19:07:33
 Re: Re: Re: Parts for 404 in reply to Butch, 12-01-2003 16:41:15
I get ALOT of 404 parts from Knight Tractor Salvage in Ellsworth, WI. (651-307-1206) Talk to Scott. He has many 404's for parts. I have some extra sheetmetal too if you need some.
bruce wellington
01-01-2004 09:04:57
 Re: Re: Re: Re: Parts for 404 in reply to Jeff, 12-01-2003 19:07:33
i believe i have a 1962 404,but not sure as i.d. plate is missing. also believe have crank problems . am looking for a used crank. compression test was good[ 160-160-160-175]hopefully someone can help. thanks
