Farmall 560 Hydraulics slow at high RPM
Matt Lindberg
12-01-2003 04:48:18
I have a 560 diesel that I put a new hydraulic pump on and all new o-rings in the valves (controle and regulator). The hydraulics work as they should at low engine rpm, but when I rev the engine up the hydraulics get very slow. the pressure reads as it should when you bottom the cylinders out at any rpm. What did I do wrong? How can I fix this?
Jimmy KIng
12-01-2003 06:18:36
 Re: Farmall 560 Hydraulics slow at high RPM in reply to Matt Lindberg, 12-01-2003 04:48:18
Did you put in a new filter if you did you might try it again .
MATT LINDBERG
12-01-2003 10:52:22
 Re: Re: Farmall 560 Hydraulics slow at high RPM in reply to Jimmy KIng, 12-01-2003 06:18:36
I HAVE PUT 2 NEW FILTERS IN IT I DONT THINK IT IS THAT SIMPLE. I THINK IT HAS SOMTHING TO DO WITH THE SAFTY VALVE.
Dan c
12-01-2003 07:52:03
We put a new filter in our 574 and it had no hydralic pressure at all. we discoverd that we put the filter back in wrong with one of the parts to it stuck in the old filter. look in the operators manual and see how it all goes together.
