i h 584
bill p
12-02-2003 03:40:57
how do you repair pressire relife vaulve? have replaced o rings. start tractor and oil flows between bolton vaulve and top of trans.
thanks
rebuilder
12-02-2003 03:59:57
 Re: i h 584 in reply to bill p, 12-02-2003 03:40:57
Bill P: Check the threads for cracks or damage from over tightening both on the valve and oriface. Is o-ring a good fit(snug)on valve?not too loose to spin?Is sealing surface on valve and oriface clean, no burrs or dirt. I use lubriplate rebuilders grease on o-rings to help keep o-ring from dragging as you tighten the item thus helping to seal, as well as keeps the o-ring from drying out.
