Farmall 460 Ta
Dean from SE ne
12-02-2003 08:27:09
I just bought a farmall 460 for 750 dollars on a farm auction and i was told it needs a new ta But i took the top cover off and the planetery gears aren't to shabby. The precious owner told me that he was going around a corner and then the tractor went weeeee eeeen then wouldn't move in ta or drive so if you have any ideas what it could be please post a message.
Brian in MO
12-02-2003 16:31:20
 Re: Farmall 460 Ta in reply to Dean from SE nebraska, 12-02-2003 08:27:09
Dean if the tractor dont move either way I would split it and look at the clutch and the shaft that goes to the transmission (splines might have rounded off) it almost has to be in front of the transmission. Brian
Aces
12-02-2003 12:53:32
If it will not drive in TA the ramp rollers and carrier are bad. The gears could be ok but you need to look at the shaft and bearings in the gears if you do a TA job.
Dean
12-03-2003 15:06:39
 Re: Re: Farmall 460 Ta in reply to Aces, 12-02-2003 12:53:32
But the tractor i was told won't move at all so i don't know about it til i get inside and get a book.
