Where to buy just rings for Farmall H?
aaron
12-02-2003 12:59:26
Hello,
I am curious if anyone knows where to purchase ringsets as standalone. So far I have only found rebuild kits per cylinder to include pistons et al. I am wanting only a new set of rings for each cylinder. Any ideas?
Thanks
steve
12-02-2003 18:43:07
 Re: Where to buy just rings for Farmall H? in reply to aaron, 12-02-2003 12:59:26
where most of these aftermarket guys are getting the rings is a "ring manufacturer" such as HASTINGS. you probably recognize them as a manufacturer for auto engine rings. go to web sight and they have everyting from minibike to train locomotive rings. you will need to do a little work yourself. need the bore, number of rings, width of ring, type of ring (oil, scraper, compression, etc) you can get plated or hardened, etc. you might even be able to have them cross reference a "set" i did it all manually for an old ALLIS, price was right and top quality.
Bruce Wa.
12-02-2003 18:29:07
several years ago i got a set right from NAPA
BIG JOHN
12-02-2003 14:08:31
My CIH dealer has always been able to supply me with ring sets. I usually take a piston with me when I order them just to make sure to get the right ones.
justin
12-02-2003 14:04:11
The ring set needed will depend on the bore, ring pattern, etc. It would be best to have the piston ready so that the part number can be read from it.
john
12-02-2003 14:03:36
i got rings and bearings for my m at a local machine shop they got them for me.if you have a local machine shop take the old parts let them look at them and see what they can get....alot cheaper than caseih for me
Bob in SE Nebraska
12-02-2003 13:47:43
I got rings only from Ken Updike at Carter & Gruenwald. You can find Carter & Gruenwald using a search. It's good to have the piston and something to measure with handy when you call.
