IH 856 stalling at high RPMs...why?
Tracy
12-03-2003 14:13:29
I have an IH 856 (diesel) that is stalling from time to time at high RPMs. I've changed the fuel filters, bled the lines for air, and check for leaks. Still the tractor stalls, but starts right back up. Is there something I can check or do before tearing into it? Thanks!
Rebuilder
12-04-2003 03:10:57
 Re: IH 856 stalling at high RPMs...why? in reply to Tracy, 12-03-2003 14:13:29
Tracy: As with the other posts make sure fuel supply is running freely. We found this problem in one of my 856"s and it ended up being the governor in the injection pump. I believe a plastic check valve or something of that nature broke and allowed enough fuel to start but as soon as you throttled-up that little piece of plastic would plub off the line. Hope this helps.
Ron 1456
12-03-2003 20:01:59
I agree with Joe.
Joe
12-03-2003 16:25:22
Sounds like your return line is plugged, Take off and blow out or replace. Also the flex ring in your injection pump may be breaking apart and clogging the return line.
same thing here
12-03-2003 14:57:52
I am sure it has a roosa-master pump and my 560 did this several years ago. try loosening the fitting on top of the pump that the return line hooks to and bleed off the pressure. As I remember I had to have my pump rebuilt as there was a "0" ring or something that had broken inside the pump. But it would die and then start right back up a few moments later.
