140 Farmall with Flail mower
Fred
12-04-2003 06:24:18
Has anyone got a picture or experience of mounting a MOTT Flail mower under a 140 farmall? Sure would like to hear comments about this arrangement. Thanks, Fred
Tom
12-04-2003 11:32:17
 Re: Re: 140 Farmall with Flail mower in reply to scotty, 12-04-2003 06:31:42
How does the flair mower run off the tractor? I have a Super AV and was wondering how it hooked up and was driven. Any help is appreciated.
Tom
Fred
12-04-2003 10:43:34
Thanks Scotty, Exactly what I needed! Fred.
Brian
12-04-2003 18:16:55
 Re: Re: Re: 140 Farmall with Flail mower in reply to Fred, 12-04-2003 10:43:34
I have a Super A with Mott (flail) mower. It works really well. Ours is a 4 or 5 foot, can't remember, but it seems to be about a foot shorter than the one in the picuture above. I've always wondered if the tractor would have enough power for a larger mower. I run the thing in first gear with the throttle pretty much wide open, it doesn't seem to matter where the grass is 3 feet or short green stuff, it does a good job. One thing that you should know if it starts to confuse you, the belt between the mower and the pully that runs off the draw bar mounted assembly is twisted in a 8 patter to reverse the direction. If you have any other questions just ask.
Brian.
ALBERT
08-14-2004 08:20:35
 Re: Re: Re: Re: 140 Farmall with Flail mower in reply to Brian, 12-04-2003 18:16:55
I JUST BOUGHT A MOTT FLAIL MOWER FOR MY FARMALL 140 . CAN YOU TELL ME WHY WHEN I CUT THE GRASS IT FLIES OUT IN FRONT OF MY TRACTOR AND HIT ME IN THE FACE WITH ALL THE GRASS AND NOT OUT THE BACK LIKE IT SHOULD DID I HOOK UP WRONG. AND CAN YOU TELL ME WERE I CAN GET A OWNERS MANUAL FOR A MOTT FLAIL MOWER.
