torque amp wrking?
Hunter
12-04-2003 13:31:29
How can you tell if the torque amplifier is working or not. Going to look at a 340 tomorrow and I know nothing about torque amplifiers. If it ain't working does it matter? thanks
Hunter
12-04-2003 16:25:44
 Re: torque amp wrking? in reply to Hunter, 12-04-2003 13:31:29
Thanks yall I just talked to the fellow and he said no TA.
dhermesc
12-05-2003 05:49:38
 Re: Re: torque amp wrking? in reply to Hunter, 12-04-2003 16:25:44
Even better. I really don't see the need for one on a tractor of that size any way. Is it a utility model?
Bill B
12-04-2003 13:34:04
Best way is with a heavy implement behind, so you can see if the TA slips. You can tell somewhat by putting the tractor in road gear and taking off, and use the TA and see what happens.
dhermesc
12-04-2003 15:10:30
 Re: Re: torque amp wrking? in reply to Bill B, 12-04-2003 13:34:04
Starting it out in road gear is the easiest since most guys won't have anything to hook it up to try it out. Just pull the TA back and let out the clutch, then as its still under a somewhat heavy lug push it forward -quickly-. If it seems like you just changed gears its working -for the most part. It might need adjustment even if it seems to be working fine.
If its out, you let the clutch out in road gear and the tractor doesn't move or barely moves you have a strong negotiation point. It will most likely work OK in the high side only limiting you to 5 forward speeds (or does a 340 only have 4?). Make sure you check by starting out in road gear with the TA lever forward. I have never seen the high side go out but I am sure it can happen, others here will tell you. We ran a 656 and a 560 with the TAs out for years without any problems.
