MD Main Bearings
David
12-05-2003 15:45:58
I have been lookign for a source for undersized main bearing for a MD tractor. I have been told that standard bearings are available through IH.
Any help would be appreated.
nick
12-05-2003 20:26:17
 Re: MD Main Bearings in reply to David, 12-05-2003 15:45:58
I have a set of .20 and .10 both are NOS Email me if interested.
justin
12-05-2003 16:49:24
I can supply 0.030 under mains for the MD along with pistons & sleeves & gasket sets. IH can still get the fronts & rears, but not the center thrust main. Make sure you have the bearings in hand before the crank is turned!!!! email me for more info
rebuilder
12-05-2003 16:21:12
David: Salvage yard I work for usually has MD mains @ rods in stock undersized but be aware that selection is limited. We actually contacted federal mogul about making new mains @ rods But minimum orders are in the thousands of sets and only for one size per set. Ouch! Try this number 1-800-248-2955.
John Vetter
12-05-2003 17:57:44
 Re: Re: MD Main Bearings in reply to rebuilder, 12-05-2003 16:21:12
Call my friend at 1-712-758-3720 Z Machine. He has .030 mains on hand. He will not rob you for them. John
