806 block heater??
806 farmer
12-05-2003 18:15:52
Needing to install a block heater on my 806. Is there a type made to screw into the block on the right side it looks like the freeze plugs are big screw in plugs that take a 1 inch square ratchet extension to remove. Any ideas
Larry B.
12-06-2003 06:07:53
 Re: 806 block heater?? in reply to 806 farmer, 12-05-2003 18:15:52
You can buy them at your caseIH dealer. They do screw in and the old freeze plug may be hard to get out. I used a 1" drive rachet and busted the plug and had to drill the center and use a hack saw blade and split it to get out. I guess the early 806's had screw in plugs and the later press in plugs because my 1964 806 has screw in and my 1967 806 has push in freeze plugs. Also if you can get two plugs out and put two block heaters in, it makes a real big difference in the time it takes it to warm up. I have two in my 856 and in one hour at 20 degrees your ready.
ny bill o
12-05-2003 19:53:10
i used a tank type heater on my int 806. not sure about using the plugs on the block, but most soft plug heaters have only half the watts of tank type heaters.
Ron 1456
12-05-2003 18:50:06
I remember seeing a block heater for a D361 at the local CaseIH dealer a few years ago. Don't know if it was IH or aftermarket part.
