Super C Fast Hitch Problem
Bud
12-06-2003 10:45:56
The block ( in front of seat ) that the hydraulic lines go through to and from the fast hitch cylinder has been removed because we couldn't figure out how to make it work. Now the hitch wants to creep down over time. Can anyone give me some help on how to reinstall the block correctly or on another way to fix the creep problem?Thanks
JWH
12-06-2003 16:05:10
 Re: Super C Fast Hitch Problem in reply to Bud, 12-06-2003 10:45:56
I just went out to look at mine. The rear hose on the control goes on the right side of the check valve block, frt hose to left side. They come straight under seat, right hose to right side of cylinder & left to left side. There's a plastic plug with a spring behind it that keeps the hitch from dropping, maybe thats bad or spring broken or weak. If your original reason for removing the check valve was for going down real slow, her,s what I did. Take the ck valve apart. there's a spool valve on one side that should move freely & an o ring if I remember right. Look in the 4 holes where the hoses screw in. Two of the holes are real small, open them up a size or two with a drill bit. I don't remember what size, it's been a few years since I had it apart. Wash it out good & reassemble. Post back your results. Mine works great,but travel at your own risk. Jim
Bud
12-06-2003 16:10:21
 Re: Re: Super C Fast Hitch Problem in reply to JWH, 12-06-2003 16:05:10
Jim
Thanks a bunch. I will try it and hope for the best.
Bud
