engine w/o sleeves
Farm w/Junk
12-06-2003 18:34:24
Hi I have a Farmall H I am going to overhaul this winter. I found a set of 560 lp 3 9/16 pistons fairly priced. I was wondering if I could remove my pistons and sleeves, hone the walle, then just put the other sleeves in. Would this work? I want to stock pull this a couple times and plow at plow days. Would it hurt to work it all day? What is the purpose of sleeves exactly? Thanks a lot.
Matt
jim in ny
12-07-2003 16:05:53
 Re: engine w/o sleeves in reply to Farm w/Junk, 12-06-2003 18:34:24
better check the wrist pin ht. before you buy them.I wouldnt run no sleeves on an engine that I wanted to work much would be strictly toy
42FarmallH
12-06-2003 18:47:13
The purpose of sleeves, exactly, is to make it really easy to overhaul an engine to like-new condition.
You can run pistons in the bores without sleeves just fine, pullers do it all the time. But when the engine is worn out again, you either throw away or pay a machine shop to put expensive sleeves in.
