B magneto
Matt
12-07-2003 02:08:51
Can anyone tell me how to test a B magneto coil at home? Thanks
terry
12-07-2003 08:15:07
 Re: B magneto in reply to Matt, 12-07-2003 02:08:51
If coil is out of mag, I can't help you.
If its in the magneto, spin the drive wheel the direction of resistance. I usually use an adjust-able wrench cause turning it by hand is almost
impossible. With a wire coming out of the coil, hold it about a quarter inch from the mag and see if the spark makes the trip. Spark should be easy to see and the bluer, the better.
I usually wrap the mag with a rag and put it in a vice.
Hope this helps.
