Shimming a lift all pump
Tim Mc
12-07-2003 09:20:16
The lift all pump in my H puts out 800psi pressure at idle my manual says 800psi is the propper preasure for the lift all pump but it is insuffiecent to run serveral implements that i have (wood splitter needs about 1200psi)
I plan on removing the pump and machining up some shims for the preasure relefe/kickoff valve.
Has anyone ever done this??
I dont see any problem in doing this, please post your thoughts.
42FarmallH
12-07-2003 09:54:13
 Re: Shimming a lift all pump in reply to Tim Mc, 12-07-2003 09:20:16
You would be better off to use a bigger cylinder on your splitter, or use a PTO pump and extra valve to run it.
You probably won't be happy with the speed of the liftall pump either, I think they run only about 8 gallons per minute. Just my $0.02 worth...
Jim
12-07-2003 11:10:05
 Re: Re: Shimming a lift all pump in reply to 42FarmallH, 12-07-2003 09:54:13
Beware of other weak points in the lift pump. Don't know what pressure, but will start blowing gasket out between backplate and the fitting where the pipes screw in. BTDT
