farmall M tire swap to 26 inch
carl
12-07-2003 15:43:14
We need to gear down our M to pull a pan.What 26 inch hubs will fit the m axle? Anyone have them or a better idea?
Ron 1456
12-07-2003 18:33:08
 Re: farmall M tire swap to 26 inch in reply to carl, 12-07-2003 15:43:14
Dual wheel hubs for a 560 and some 9 bolt combine wheels and you are in business.
get some dual hubs and re
12-07-2003 16:50:21
and get the rims off of a 403-503 combine and get the welder out and some reinforcment rings out of gemplers and you will be in business.
grizzly
12-07-2003 18:41:31
 Re: Re: farmall M tire swap to 26 inch in reply to get some dual hubs and re, 12-07-2003 16:50:21
found some 26" combine tires and wheels they had four holes in the rim for weights, the same as the cast hub on a m. the hub has 5 or6 webs going to the ring that the rim bolts to, i cut the web at the base, towards the center of the hub, as close as posible. [cut with a grinder and cutting wheel or a portable chop saw not a tourch] if no weights bolt together, if weights use all thread [i used grade 3 allthread and i have 5 weights on each side and i realy abuse my m and have had no prob] do a little measuring first it took me about 8 hrs, but it was well worth it i have two m and the other is stock the one with 26"in 3rd is about the same as the factory in first
Dick Davis
12-08-2003 01:32:30
 Re: Re: Re: farmall M tire swap to 26 inch in reply to grizzly, 12-07-2003 18:41:31
Sounds like a neat job grizzly. Any chance you could post a picture or two? Would like to see the results. Dick Davis
grizzly
12-08-2003 17:34:20
 Re: Re: Re: Re: farmall M tire swap to 26 inch in reply to Dick Davis, 12-08-2003 01:32:30
no way now but if you can get to a tractor junkyard look for wheels with the weight holes the same as the m i only give $50 for both with 90% tread and very little dry rot got lucky i was determined to make them fit got lucky agian i have a junk m also so if i messed up the hubs no big deal so be careful any Q email me
jed
12-08-2003 10:08:54
Get a pair of hubs from a MH 44, they are 2 and 3/4 inch. They will handle a nine bolt hole rim.
All you need then are the 26inch 9 bolt hole rims and tires.
